Attached is a copy of a Wiggler Manual. Yes, it's a manual from a General. If someone finds a better manual I'd be thankful for it!
Addtionally, please note the cut/paste from Burley. These are not indicators. They don't tell you how much you are out or which direction.
Testing Machine Tools: Burley p38-39
"Non-measuring Indicators. — These instruments (sometimes called " wigglers ") do not admit of the actual measurement of errors, though they enable the presence of errors to be detected. They usually work on the principle of magnification, the operation of which causes the movement of the indicating element to be several—in some cases, many—times as great as the actual error, whether this be one of eccentricity or obliquity. As instruments for use in precision testing they are practically worthless except in those cases wherein only qualitative results for the purposes of correction are required."
You can use them to edge find, and check parallel of the X, Y or Z. (note that the depth is limited to the length of the stylus). It's really handy device for finding center when on the DP!
There may be more precise methods. But, she is quick, easy and if you accidentally drop her your stomach won't get queasy.
Several local mentors have beat into me the idea that everything really comes down to "fit for use".
Daryl
MN
