First Lathe Decision
I sent you a pm . I'm not in any hurry , they are always here . I threw this out because you were in close proximity and both machines were mentioned in your first post . :) The BP is a series 1 2HP VS head btw .
Sounds like a nice match. You just need to negotiate a package deal with @mmcmdl to give you a little help, at least advice, with the moving :)
It looks like a concrete apron in front of your shed's door. Sounds like a perfect fit with one of the Sunbelt rental drop-deck trailers, as long as the lawn isn't too muddy. Frozen ground would work well ...
I rented an all terrain fork lift for 1/2 day and had it for the entire weekend . Only took 30 minutes to load everything into the basement , then I helped the neighbors lifting shingles onto their roof . What he has is a simple move . :)
