I need to make some work holding vise jaws. They will project a little over the top of the vise with a 1-1/8" hole and a couple of notches. Starting out with 1" x 1-1/2" 1018 steel. Going to hog out excess material. Clamp together with 1/4" spacer between them and bore out. Thinking about this, I would like to add a small chamfer or round the edge a little. This is not critical. It should just look nice.
Here are the options as I see it. File the edge. Use a hand die grinder and burr on the edge. Put in a chamfer or radius bitl, clamp to rotary table and go roundy-round. Or with piece already clamped and located, switch to a fly cutter and lower it into hole. I'm thinking to install the flycutter and reference it to a flat piece of steel. Hold a 45 degree angle along the side and mark the bit. That takes care of the 45 degree chamfer and fly cutter down angle. Grind straight across to match the mark and then grind a few degrees rake into it. What I end up with is a flat, straight angled edge almost like a scraper. Start high and just lower it down into hole.
I couldn't find anything like this in the forums. Has anybody doe anything similar? I don't see why it wouldn't work to cut a 1/16" or 1/8" chamfer. As always I look forward to the answers. Thanks in advance to all the people who take time to help!!!! Charles
