- Sep 22, 2010
- 898
My first Metal lathe was a Craftsman (Dunlap) 109 series lathe, which I quickly outgrew. My mentor in the tool repair business had a colleage that had closed his shop due to health issues and arranged to help me get a Logan 9x28 Metal lathe which I had for many years and most days it did what I needed it for, mostly turning commutators on motor armatures, but every so often I needed just a bit bigger. See the piture below where i am repairing a cutterhead from a 24" General International Planer
After searching for many years for a used piece of iron, and never finding anything, We are in an area where used lathes are like teeth in a chicken, non existant! I finally decided to get the Gosan 1440V from Modern Tool.
This lathe is made in Taiwan in one of the more established factories, which also makes the Colchester and Sharpe branded Lathes http://www.shyesheng.com/products_SSM.asp
The fit and finish is much better than the average overseas import, the electrics are good quality and overall it has been a real nice machine, capable of higher precision than I am. LOL
I have put it on Footmaster Castors so I can roll it away from the wall whenever I need to get behind it, but can level it for use.
I had wanted a lathe with a T-Slot Crossslide, but ended up that this machine did not have that feature so added a dovetail slide to mount the undercutter on.
Also the halogen lamp was an extra accessory and I made up a plate to mount it and to offset the coolant tube and the DRO mounting mast as the tailstock lock lever overlapped them when I got it.
Oh and Charlie is the shop watchdog.
Walter
Walter
