- Nov 24, 2014
- 3,191
I've been following along and need to comment on a couple of design features.
I suggest adding a second worm support (reddish part) on the other side of the spindle and extending the worm shaft so that the worm is not cantilevered as currently shown. I see that such a change will cover the existing angle engraving on the trunnion, but that engraving can be relocated to radial marking on the worm support. The gear mesh will be much more durable if you support the worm from both sides.
Also, I think I see two large jam nuts on the back of the spindle. Consider the hex size and how un-common wrenches will be. Instead of buying or fabing wrenches, I suggest using a single cylindrical nut (maybe knurled OD) with some blind holes for a pin and at least one threaded setscrew. Drop in a brass ball, to protect the spindle threads, before installing the set screw(s).
