- Jun 26, 2018
- 1,733
Yep, pretty much I'm going to make 2-3 sizes of bits to start, and otherwise make them compatible with the commercial/professional 1/2" diameter bits (which are 1.75" long).So to be clear, this is the list;
1- ErichKeane-cutting bits (better be one damn extensive set!) ; ) #3 on diagram and misc bearings/screws
2- GunsOfNavarone Backing/angle plate Part #1 on diagram
3- ttabbal spindle housing
4- T Bredehoft) sindle
Yeah, bits for these are expensive! Fortunately minor dressing of them ends up being just a stone across the flats.Hmmmm...interesting and concerning. I don't do HSS, say on my mill, as I do not have sharpening skills, I go carbide inserts. So, I won't be sharpening bits, I'll be buying new ones. $100 a pop??! I guess I should do some searches for .500" broaching bits....there has got to be a reasonable source somewhere!
Do they have a good image of one that I can perhaps see to copy? I just was on my phone and saw they have bits at 1/2 of McMaster prices.I gotta say...their adjustment free holder sounds pretty awesome. I really am a bit lost as to why a small amount of movement of the spindle (radially-so the broach can center itself), isn't possible for us (?)
This place : has them ft $50 each! https://www.polygonsolutions.com/ro...ches/hexagon-rotary-broaches-half-inch-shank/
They even have through-hole versions, which have the ability to go into a tighter hole, since the air can escape backwards!
Any sort of steel works, nothing on the tool other than the bit has a critical hardness. 1018/12L14 works, as does 4140.Broaches.. I can't imagine using as large as 1/4, I don't work with screws that large (3/8) although I probably could. Most of my projects use screws smaller than 1/4-20. down to and including 4-40. I have tapped holes 2-56, but certainly never will make a screw that small.
Send me a finished print and some steel, I'm ready. Oh, what are we making this out of? I'd suggest either annealed of half hard 4140 or such. If this has been discussed, I missed it, sorry.
