- Feb 10, 2014
- 366
Has anyone else had any issues with the head clamping bolts (lock the head to the column) spinning in their cast bosses? I have had an issue with them since I got the mill secondhand. I ended up pulling the bolts out totally and found the threads were badly distorted from over tension. I can only figure that someone overtightened them repeatedly. The boogered up threads locked the nut to the bolt, causing the bolt head to round over and spin in its boss. My solution is to replace the 5/8" bolts with 3/4" bolts with the hex heads milled down to fit in the boss. Also, what size and thread type are your bolts? I have a sneaking suspicion that the bolts I pulled out are not original. I am replacing with a 3/4" fine thread bolt with a 60* thread. Are Acme threads more apro-pros?
