So I got my new to me SB 10L which is in decent shape, but I wanted to go ahead and change all of the felts and figured while I was at it, I might as well go ahead and do the work to paint it. I am in the middle of disassembly and I am taking the Bull Gear mechanism apart and the book says to remove the "taper pin" in this bushing. I tried a punch in what appears to be the only direction it can go. I then sprayed some carb cleaner on it to get a better look at it and it almost looked like it could have been a flat head screw so I used a small flat head and gave it a couple of taps to try and set it and unscrew it. Still no luck.
Before I screw something up, I wanted to see if anyone has ever seen a flat head screw in this spot or if it is for sure a taper pin and I just need to work at it more? I put some kroil on it, but not sure that is going to do much in this case as it doesn't sit at a good angle to let is soak.
A couple of pics. I think the flat groove is from me trying the screwdriver.
Other side:
Thoughts? Thanks in advance.
Other side:
