Help!
What is the best way to insure that a hole is centered in a mild steel shaft?
I have squared the drill to the shaft, and center punched, yet I still have a problem with the hole starting off center.
I am trying to lengthen a shaft by drilling and taping the shaft, and adding another shaft on it's end. The addition will be turned and threaded, so as to be screwed into the lengthened shaft.
Any ideas on this is appreciated.
Regards,
Regards,
