- Jul 5, 2014
- 2,787
I was running these today and was kinda bored, my other two machines had long cycle times and I thought people here might like to see a vid I made of cutting some stainless parts. We have been using the high efficiency machining for a few months now and its dramatically cut the cycle times when we use it.
The material is 15-5 and I'm using a 5/16" 4 flute carbide coated end mill with a .03 radius. The RPM is 5600 and feed rate is 88 IPM. Th step over is about .02 depending on if its a profile cut or a pocketing cut.
You can't really hear the cutting because of the air blast we use to clear the chips away, and excuse my finger in the middle of the vid, I was losing my grip on my phone.
https://www.youtube.com/watch?v=4lwOHJ-EYKs&feature=youtu.be
