If I had bought that condo down in Surfside years back , I could cover the New York , Baltimore and SC plants !Farther from the mountains...
I ran the manufacturing plant up in Md back in 86-88 and left for other oppurtunities . It used to be called Filterite back then . 33 years later I'm back at the same company now known as Pall Corp . We used to have 4 plants up here within a mile of each other and are now down to one . Funny thing is my property up in the Adirondacks is close to our Cortland NY plant . This new SC plant is fairly close to Surfside Beach SC where I want to retire to .We used Pall filters in our plant in Eden. A great improvement over the previous system we used, which was from the early '80's. Odd, about 20 yrs ago I ended up buying a motorcycle from a man who helped install that original system in the brewery, 1982-3. Now, someone from the subsequent system installed crosses my path. Small world. A guy from Georgia came in to check our system every so often. I've not kept up with him since the brewery closed, although my Daughter will see him occasionally, as he services the system at that brewery. Hope things work out for you.
