Thank you! I'll read up on it I had no idea how to look this up
Or, converted to decimal degrees: 7.125 Degrees.
7 + 7/60 + 30/(60*60) = 7.125 Degrees (If my coffee is working this morning...)
In my workshop, the answer would be 7 Degrees plus a skosh.
Yep. But make sure both the indicator tip and the tool tip are on centerline; any height error will result in an angle error.If I was going to try and match the angle on the lathe nose set the compound to match it with an indicator. Then mount the new backing plate and machine the angle. It won’t matter what the angle is. The back plate will match the angle.
A whole bunch of this.Yep. But make sure both the indicator tip and the tool tip are on centerline; any height error will result in an angle error.
That probably won’t be good enough for a spindle nose.
Max, how much is your time worth to you?
You’re going to play hell getting that taper right, especially as there is most likely a shoulder or pocket involved.
This is a situation where if at all possible I would purchase the back plate.
I agree with the above, particularly by RaisedbyWolves. Buy if you can.Yep. But make sure both the indicator tip and the tool tip are on centerline; any height error will result in an angle error.
But... if you are going to set a specified angle, the best process I've come across for setting a compound is by Joe Piecznski in this video. However, in your case, one of matching an existing angle, use the indicator on the spindle itself.
A friend and I machined 10 backplates for an pre-WWII Rivet 1020 (my avatar image) L00 spindle nose. Some of the resulting backplates would "stick" to the spindle, indicating the taper was that close, some don't, but they all worked. I would have bought the backplates, but the threads were 4 tpi, which was proprietary by Rivett. Only ones available were 6 tpi.
Rick
