R
Robert LaLonde
Forum Guest
Register Today
How much taper engagement should there be between an R8 tool/holder/collet and the surface of the R8 taper inside the spindle?
I would think must of the length of the taper, but I recently tested a machine where there is just a tiny contact ring near the large end of the taper on the tool. I tested a solid tool holder by marking it with a sharpie marker, but on other tools used in the same machine I could see the scuff mark in the same place. No other part of the taper showed signs of contact.
