I know that sounds like a lame question. The reason I ask is this.
When drilling a hole and your final dimension is say 1/2" or larger, do you drill just a pilot hole and then the final size or do you drill 1 or 2 more times to work up the the final dimension? This would go for flat stock as well as round. What is considered the proper method?
I will add that all my bits are 118 degrees and extremely sharp.
Thanks!
Thanks!
