- May 3, 2020
- 99
Hey all, this is actually a work related question but I figured the folks on here would have some good suggestions. At the end of the day today while disassembling some components at work I snapped off two 2-56 fasteners inside locking helicoils. One is above flush so there's a chance of getting it out, but the other is flush with the part, I'm thinking I will have to drill it out on our Bridgeport. The holes in question are part of a 12 hole round bolt pattern. I have access to the blueprint for the part, which provides me with the bolt circle diameter and degrees, meaning I can figure out the X and Y coordinates of the holes. The problem that's occurred to me is how to properly indicate the bolt pattern so that everything lines up? The mill does have a DRO, but to my knowledge bolt hole functions on a DRO can only be used to make a new pattern, not indicate off an existing one. I had the thought of sticking gauge pins in two holes across from each other on the pattern, holding a parallel to them and sweeping the parallel with a dial indicator to get things dialed in. Will definitely work, may just be tedious/time consuming. Anyone else know any DRO tricks or any other methods that might get me there?
