Hi,
I just bought a Van Norman 16 mill, and in going over the tooling that came with it, I found that 10 out of 20 or so collets that came with the machine have damaged key slots in the collets. I'm pretty sure this happened because someone cranked the drawbar up with the key in the spindle resting on the side of the keyway (not in the keyway). I found out this is very easy to do!
Anyways, these collets are very expensive since they have the Van Norman 5V (or "C") external taper-- so I want to repair these collets with the mill AFTER I get some experience with the machine--maybe in a month or so.
I found a drawing of the 5V collet (attached).
Questions:
Can someone tell me what tool hardness is needed to clean up these slots? (I really have no idea what steel the collets are made of).
Do I just order a "slot cutter" from say, Niagra, with a diameter of .5 inches and a slot cutting width of .188"? (I'll take the next month to figure out beginner horizontal milling, layout, etc etc.)
Thanks in advance,
Bob
Questions:
Thanks in advance,
Bob
