- Jul 11, 2014
- 496
I once posted on this forum how 'Stupid Just Follows Me Around!' Stupid struck again yesterday."jawdrop:
I was milling & drilling my carriage stop project. I had pilot drilled the mounting hole for the micrometer barrel. I was going to, I say 'was going to', ream the right size hole, cut it with a slit saw, then drill and tap for a small hex cap screw to clamp/tighten it on the barrel so I could remove it if I wanted. Didn't get that far. I was looking through my reams and realized late in the process I didn't have the right size. I then decided to just 'plunge' mill the hole with a 1/2' end mill. I got everything set-up, inserted the mill and did the job. "Wait! What's This!??" :shocked: I found, when trying to fit on the barrel, I had plunged with a 3/4" end mill. AAARRGGGH!:banghead: Same shank size, together in the same bin and yours truly did not double check. You'd think I would notice...NOT!
I did not totally ruin the piece, I can bore the hole out larger and insert a bushing. I will now have to use a set screw instead of my original plan. :yousuck2:
I was so aggravated I quit for the evening. I will be back at it today and accept it as a learning experience. The old adage, "Measure twice, cut once." could be applied as "Check three times, mill once."
I met and embraced Stupid again yesterday. "Hello Stupid, would you like to help me with this project?":rubbinghands:
