- Nov 21, 2010
- 1,602
As watching Tubals latest release on a SB9 thread stop, when it gets to trigg. then
my brakes go on. So I left Tubal a comment on one I made on a shaper that for me
was way faster and with very little math. I trued up 1/2 stock scribed the layout
hogged out the bulk with a 4"grinder set the machine to the proper degree cut the
Vss cleaned up the bottom, then drilled one end then slit that end vertically, ran a
1/4 20 tap in the center piece. Ground a 1/4 20 to a point screwed that into cross
slide then wacked the stop then drilled stop little bigger than 1/4". done a little under
an hour. No math no dowel pin lock no critical width its really no more that a carriage
stop. Then I cut and epoxied some brass shim stock to its Vs. No doubt these things
were probably already made 50+ yrs ago I never saw one. No expensive mill dovetail
cutter. Actually this can be made from plastic or something cause one doesnt animal
the cross slide into it. Its just a -0- reference point. Came out good. Just another
rainy day thing.
rainy day thing.
