- Feb 24, 2019
- 927
I'm going to add a stepper drive to my X axis on my Smithy Midas combo.
On the left, in the image below, is the piece I'm removing to make room for the timing gear on the right.
The problem is that the timing gear is 7mm wider than the gauge I'm removing so I either need to shave the gear down, where the set screws are, or remove another part from the X-axis shaft support. That is doable but I'd have to add 4mm in shims because that part is 11mm.
My plan.
Shave down the set screw part of the timing gear and then add set screws directly into the gear itself. I have almost 2/3 of the gear that will have belt on it when it's all assembled. I don't think the holes in the gear will affect performance but that's why I'm posting this to see if there's something I'm missing.
Also, I ordered a 4mm broach today for the timing gear. It's probably the only time I'll ever need it so I didn't buy anything fancy.
My plan.
