- Dec 8, 2015
- 111
Hi All.
I purchased an old D50 ? Kurt vise. When I disassembled it, I seen thatit was missing the thrust needle roller bearing in the rear. The flange on the main screw was just bearing on the back casting. There was nothing in the counterbore where the bearing would usually be. I ordered the rebuild kit from Kurt.
The OD of the bearing kit received is too large. The bearings and washers received are 1-7/16” OD and 7/8 ID. The counterbore in the vise body is 1-1/4 OD x 3/8 Dp.
I called Kurt Mfg. The young man that helped went out of his way to dig into this and find the correct setup. He called me back and told me that after digging around he was told that the older vises with the main casting marked “A50” did not utilize a bearing. ( Note that all the other castings of the vise are marked” D50”.) It was suggested suggested that somebody may have added the counterbore. That seems unlikely to me since I could not find a 7/8 ID needle thrust bearing with that small of an OD.
I machined up a brass bushing – fitting the counterbore to utilize as a thrust bearing and it all seems to work just fine.
I had been thinking about and was curious if anyone knows what the “original” configuration would have been? If just a solid thrust bearing was used originally I would not think they would have made a counterbore so deep – nor the flange on the shaft bigger than the counterbore - if the flange were to fit inside the counterbore it would help keep the chips out.
Thanks Jim
Thanks Jim
