- Jan 9, 2016
- 120
I'm getting ready to build a workstation for my new-to-me 7x10 lathe. The top will be a 4" torsion box, 3/4 MDF faces, 3/4 ply ribs, all covered with laminate. The lathe will be bolted down from the bottom side through a couple of small access holes.
Is a laminated surface durable enough for metal work on this scale? I don't see why not (impervious to most solvents and lube, cleans easily, etc.), but thought I ought to ask so I don't find out otherwise somewhere down the road.
If laminate is good to go, should I choose a white, light, medium, or dark color? I work in a shop that handles a lot of laminate, and have free reign over the colors I choose as long as it's old stock or scrap.
Also, are castors OK for (again) a hobby lathe station of this size? I'm looking at 4x, 3-4" double locking castors (rolling lock and rotational lock). An alternate there is a true mobile base with retractable castors. I don't plan on moving it a lot, but I have also learned that plans are only good until the first problem is encountered
Full plans also include removal of the stock chip tray, a small removable dam on the front edge, and independent bolt-on rear and side panels. Lighting options and power management are also in the works, as are some drawers, dividers, and cupboard-style storage space.
Thanks!
Thanks!
