T
Tom Griffin
Forum Guest
Register Today
Here's a quick and dirty project for the mill that will get used all the time, laminated step blocks. To use them, all you do is spin out as many layers as you need and slide them under the clamp. They are a lot more convenient than stair step blocks and a lot more stable.
The blocks are made from 2 pieces of 2" x 2" x 1/4" and 12 pieces of 2" x 2" x 1/8" aluminum sheet with a 1/4" socket head cap screw to hold them all together. The bottom 1/4" piece is tapped for the screw and the top 13 pieces have clearance holes all centered and about 1/2" from the edge. The screw is then staked in place or Loctited to keep it from rotating. If you want to get fancy, you can mill radii on the corners for appearance.
Tom
Tom
