- Dec 17, 2012
- 745
Since my shop will be off-limits until September (I've summer guests in my holiday house, which is just above it… not the case to make too much noise… they are not machinists :biggrin I have some spare time to make researches for a lot of things.
A friend of mine is a sculptress, and I looked how to make a bronze furnace for her works, since the foundries "for artists" are pretty expensive: for a piece like the one below, 40 cm high, the casting price is almost 2000 euro (but patina is included :biggrin.
Alas, homemade bronze is not exactly easy as lasagne to be done, and I was thinking to an alternative solution.
Aluminum would be easier than bronze, but this post by Hvontres (thanks, Harry!!!) pointed me toward low temperature alloys (Wood's metal. Field's Metal and similar) which could be a solution to make small metal sculptures with an affordable price.
Basically the "artsy" needs for this alloy are:
- must not be too expensive;
- the color must not remember recycled cutlery: even if without the patina of the bronze it must be at least dark or brown;
- must bear the "sun through a window" temperature, which can be over 50°C, without to melt like a candle;
- must be workable at a "kitchen" temperature, to avoid the need of a furnace;
- must not be toxic (even if I'd be happy to give to some of the most annoying clients of my friend a plutonium sculpture… in four pieces to be assembled :biggrin
I'm sure the collective knowledge of the forum has a good solution!
