neato
Dickybird over on HSM has a neat trick where he heat shrinks 2l soda bottles (PET?) over a form to create fan duct. Just be aware, if you aren't already, that there'll be a hoooge amount of back pressure trying to force air through the motor, so either get a fan to suit or mod the duct so that some air flows over the outside of the motor. 12V PC fans offer a lot of options and 120mm ones can flow a lot of air, plus if you use an eBay tach you could run the fan and tach off the same 12V power supply.
