I have a Harbor Freight (HF) 9 x 20 lathe and for sometime I have tried to fit it for a toolpost (TPG) grinder. I need something that will not only grind parrallel to the lathes axis I want to do angle grinding as well. Example,the 60 degree dead centers on my lathe.
Little Machine Shop (LMS) has two types of what looks like well made tool post grinders my question is can they be adapted to grind on an angle. It would appear the compound rest has to be removed and the TPG would have to be mounted on the cross slide for parrallel grinding only. I can't see mounting either of these on the compound rest
Has anyone out there had experience with this problem or is my thinking wrong?
In the meantime I have worked up a simple design in the hopes of keeping the size and weight to a minium. I purchased two flanged bearings (with set screws) and milled out the bkts for homemade pillow blocks. I have scribed out a base on a piece of allum and a means to secure it to the compound rest. I need a motor. LMS has a motor that is light and what appears right for the job with one exception it is rated at 18,000 RPM,my bearings are rated at 8000 RPM.
From what I'm told this can be controlled with the right pulley ratio,I would like to keep the size of the pulleys to a min.
Can someone suggest a simialr type motor (lower RPM) comments suggestions greatly appreciated
John
John
