Hi all,
Found this forum recently, just never posted til now... maybe a little background might help...
Finally picked up my first metal lathe around last Christmas, it's an Atlas 10F H54. No hurries with it as it needed a good cleaning, and since I did that... might as well paint her up too. New timken bearings a few missing parts found on ebay, and she's running now... just need to finish painting the covers and shim the carriage properly (shim stock arrived just yesterday) to sweeten everything up nicely. From what I've read so far, it looks like I need/want a decent ER-40 collet chuck to help me make a bunch of duplicate sized parts. So I talked with Jan this week at tallgrasstools, and he's making up a kit for me that ought to be ready to ship this week, here's a link to his ER-32 Collet Adapter Kit.
This brings me to my question... I need to make a v pulley. Atm I'm using the stock motor w/pulleys and need to make the pulley that will ride on a treadmill motor with a 17mm spindle shaft. ~1" of clean 17mm shaft terminated with a coarse metric pitch thread which originally was used to hold the flywheel in place. Should I just cut off the threaded portion off of the shaft, or remove the spindle from the motor then mount in the lathe and cut the threads down? Second option would mean that the pulley would have to be stepped internally to accept the shaft.
Looking around the net I found MACHINE SHOP TIPS #65 Lathe Project Pulley Part 1 of 3 tubalcain where Tubalcain first drilled to just undersize for the bore, then reamed to final bore size. I reeealy can't see me getting a 17mm reamer for this one-off project and I don't have metric drills that size atm. What if I were to bore a hole as close as I can get to 17mm, just undersize, then make a boring bar of some sort out of some O1 drill rod stock that I have? Could I expect to come away with a "close enough" fit on mounting to the shaft, or should I try something else?
I'm not sure of my abilities to cut accurately right now, especially since I'm new to lathes, and the fact that I'm still fleshing out what needs tweaking/tightening/optimizing for accuracy, etc. I'll eventually figured it out, but for now... any tips?
P.S. if anyone needs a G5523 Triple V-Groove Pulley - 3" Dia., 17mm Bore, I can make you a good deal... (didn't realize that the V wasn't sized for 4L belts , but 3 )
