- Sep 10, 2013
- 562
Hi All
Well I'm was doing some cleaning lubing and found a crack in the Reversing tumbler bracket, part# DL-321. Does anyone know where I can get another one. I could grind it out TIG weld it with some Stainless or hi nickel but it most likely will crack again. Anyone have an idea where to get a good used or even a new one? I will replace this part with the Threading Clutch but that is a ways off and some lathe work will be needed before then. The center gear is a little floppy is why I removed it and cleaned it that is when I found the crack.
Thanks
CH
Thanks
CH
