It was hard to get back behind mine but the leg is 29 3/4" and an additional 1 1/4" to the top where the threaded adjustment goes into the motor bracket-- if you make it to adjust between 30" up to 32" you should be okay---unless someone else can measure their leg adjustment better---Dave
Marc - My pedestal was a whole lot easier to get to.
I also measure 29-3/4 inch for overall height.
Upper end is ~3 inch overall diameter, about 15/16 inch thick, with a 2-1/4 diameter x 3/8 inch deep pocket.
Base is 5-1/8 inch diameter, about 7/8 inch thick. It has 3 x 11/16 thru holes, on about a 3 inch hole center diameter.
I can't provide an adjustment dimension, as my Logan it's still in pieces all over the basement floor.
