I got my new lathe moved today. Made a few chips with it. This is the first Clausing lathe I've had. My first impression was that compared to other 10" lathes I've had, it seems like a fairly rigid machine. I haven't quite figured out the way the feeds are grouped on this machine. I'm sure there is some rhyme and reason to it, but at first glance it seems like you have to really jump around to move from one feed to the next faster one. The machine needs some tlc but there's doesn't seem to be anything major wrong with it. The previous owner was powering it with a static converter. I tried running it with the static converter I power my mill with, but the motor wanted to heat up. I moved the machine and plugged it into my rotary phase converter and it worked fine. I've had this problem before and it baffles me. The mill has a 3hp motor and it runs fine on the static converter. I haven't looked at the motor plate on the lathe but I'd be surprised if it's more than a 1 hp. Is there some difference in the way motors are wound that would make them heat up when powered by a static converter? Anyway, the lathe came with a 3 jaw Buck adjustable chuck, faceplate, drawbar and 4c collets, live center, jacobs chuck, steady rest, and other misc. tooling. I'll post pics tomorrow.
Chuck
Chuck
