Im looking for a source for dual plunger limit switches you see used on milling machine x axis power drives. It will be used on a power drive I’m making for the head of my mill drill.
Howard -
I don't know how far you've gotten with your project, so feel free to take this with a grain o' salt ...
I added a powered head lift to my RF-30 clone mill -drill a few years ago. Used a "big satellite dish" positioner motor, which has limit switches built into the gear head. No need to wire up any external switches! Powered it with a 24 volt DC supply I already had on the mill. These motors will work with anything between 24 and 36 volts DC. Maybe lower voltages, but I think power would suffer. 24 VDC gives a very nice rate of up-and-down movement. And it appears my initial concern about the life of the nylon gears has not been an issue. It's worked well since I installed it.
Yesterday was a busy one for me, a friend came by with a project for me. He wanted to replace the bolt on his high pressure air rifle. The original bolt is pot cast metal. For the replacement bolt, started with a Hex brass rod, turned down a shank and allowed the knob enough material to turn...
