Total newb here. I have a couple crusty chucks for my new to me lathe. Both 6" with 1 1/2"-8 spindle threads. One a 3 jaw and one a 4 jaw.
I decided to take them apart to clean out the crud and rust. The 3 jaw had all the jaws numbered and a corresponding number on the "body"? of the chuck. I did not remove the back just used a wire brush and solvent to clean it all up. Anyway the 3 jaw went together exactly as it was.
The 4 jaw has numbers on the chuck near each slot but no numbers on the jaws or screws. I marked them all with a sharpie just to avoid mixing them up. I just used a wire brush and solvent to clean out the old crud.
The 3 jaw is an old Union, the 4 jaw is an old Cushman. Now my questions.
Does it really matter which jaw goes where on the 4 jaw independent chuck? What should I use for lube inside these bad boys?
Sorry if this has been covered before. I just spent quite a while using the search function on just about all the forum sections. Maybe I need better key words. I even just used "chuck". Didn't find what I was looking for.
