Getting ready to order the DRO'a for a lathe & mill and see you can get different length of scales up to a point without extra cost. Since they could be cut down and shortened, wouldn't you just want to order the longest length for all and cut off what you don't need. Later if you have an issue with one getting damaged you could use the pieces you cut off (if long enough)??
