- Mar 20, 2014
- 440
I was given a big pile of these brackets made out of 3/8" aluminum plate (see pic). What is the best way to cut the welds, so that I can use the flat bars for other projects? If you look on the left side, you can see where I started cutting the weld with a cut off disc in a 4" angle grinder, but the disc got gummed up with aluminum particles. thanks, JR49
EDIT, picture didn't show up--will try again
