I think you would need to extend the ram so far out to work on most things it would be impractical on a manual mill it’s more suited to a cnc.I saw a Kurt DX-R and thought that would be interesting to use.
Has anyone here used a reverse vise on the mill?
True but, with the length of the vise body, it would limit table travel. If I ever get back to work I’ll turn mine around to get a visual.@Firstram, actually it would be the opposite. You would have the table closer to the column of the machine.
From what I have seen, a cnc vice describes one that can be mounted on its side & often has long clamping slots along the side instead of the 2 blind slots for the tee bolts.What would make it a cnc vise?
