- Jul 28, 2017
- 2,393
Yesterday I ran into an "interesting" problem. The fan motor in our old food dehydrator seized up so I went looking for a replacement. It turns out that the motor is physically identical to the one used in a very common bathroom exhaust fan (that probably was no accident). Since we have a load of stuff in the dehydrator I immediately ran over to my local big-box hardware store and picked up a replacement motor. A little while later, congratulating myself on a quck & easy job, I turned the dehydrator back on -- and discovered that the motor turns the opposite direction compared to the old one, so the air flow was reversed! Flipping the fan blade over didn't work (I should have known that before I tried it).
I looked online for fan blades with a reverse twist on them but nothing that was an easy drop-in. Thought about making a fan blade but before going down that rat hole I did a search for reversing the direction of a shaded-pole induction motor and found exactly what I was looking for -- here. Now that's a solution I can get behind! And since I used wire nuts to install the replacement motor (rather than soldering) it will be a quick and easy R & R.
This will be the third motor in the food dehydrator. It was difficult to find a replacement after the original motor died, and that was 15 to 20 years ago. The little appliance-parts shop we got it at is long-gone so finding this little trick will greatly increase the availability of fan motors.
