- Jun 20, 2022
- 220
Guys I'm going through my mill doing some maintenance. I have an RF30 knockoff. It has a two collar preload system with very small divots in the collars which I assume are for drifting with a small drift and hammer. I loosened the locking collar and tightened the preload collar with the belts off. It was rather easy to tighten, and because of the small size of the divots it is VERY difficult to overtighten it (I think) simply because the drift with pop out of the divot if you hit it with any real force.
I noticed a very small amount of increased force to turn the spindle. It still spins easily. I ran it at 900 RPMS for 5 minutes. The upper bearing did not heat up at all. The lower bearing warmed up to above room temp, but it was warm, not hot to the touch.
Is there a rule of thumb for mill spindles? I assume the answer is tight, but doesn't get "hot" when you run it? How long should I run it and what speed to check for it getting too hot?
Thanks!!
Thanks!!
