Saving An Old Craftsman Floor Jack
astroracer
Apr 1, 2015
76
A friend of mine broke the diecast universal joint in his Craftsman floor jack. He couldn't find a replacement universal so, in looking at the broke pieces, I figured it wouldn't be that hard to make a new one out of steel.
The pieces aren't that big. Only 3/4" in diameter. All of the parts after dis-assembly.
I found a piece of 3/4" diameter steel in the drop pile.
I cleaned up the OD in the lathe, faced off the ends and drilled out the bore's for the mating parts. Test fitting the parts.
With that done I clamped the piece in the vise on the mill and machined off both sides.
With that done I picked up the ends and center drilled for the pin holes.
After drilling out the pin holes I flipped the part 90 degrees in the vise and hogged out the center portion with a 1/2" end mill.
After some deburring and cleanup.
I split the piece into two.
After rounding over the cut ends and a bit of assembly and I had a new U-Joint!
This was fun project and it will save an old jack from the scrap pile. :)
Mark
That is why it is fun to be a hobby machinist. I have also made small repair parts for something that would otherwise ended in the garbage or recycle bin.
Mark
That looks good, and will prob outlast the rest of the jack.
Nice job. Always good to save something useful. Mike
Nice work - clever too! Those look to be the same as the ones on an Atlas mill power feed. The universals on my Atlas mill where broken when I bought it and I made replacements but never thought to mill both sides at once - that's just mad problem solving skills!
