- Nov 9, 2017
- 222
Well, I'm back with another (probably dumb) question that I can't find an answer to googling or digging through the info that I have here. I'm about to put the drive assembly back in the cabinet and started looking at this - it doesn't seem right as it came to me.
The shaft that the lever rotates to put tension on or off the drive belt has a collar with an indent in it. It looks like the arm with pin hovering above the collar might be supposed to fit in this indent at some point of the rotation. But, as this thing is currently assembled the pin never contacts the collar, much less goes into the indent, and the indent itself is apparently at a random point in the rotation, not at one end (tension on) or the other (tension off) or even right in the middle.
I know South Bend wouldn't go to the trouble of making this setup if it didn't have a function. As currently assembled this does nothing at all. Any advice?
