- Sep 3, 2023
- 246
It looks like some of the lines are level, and some have a definite slope to them. Did you do this in an effort to make sure water / condensation will always flow back to a blow off point?
That is one thing that I have been thinking about for when I actually get around to getting my airlines run better. I plan on making sure the runs are straight lines with slope so water will always run back to blow out pipes.
Currently I have a temporary ( about 20 years now) hose attached to the ceiling that goes from one corner of my shop to the opposite corner where I have a hose reel on the wall. I have 150’ of hose on it, so is real handy to pull out air up tires outside.
But, it will run out of air pressure/ volume quickly with a die grinder/ impact wrench.
And I’ve had problems in the past since the lines has droops in it on the ceiling, of the line freezing up in the winter time when I had no heat in the shop. I have heat now when I go out to work, and this winter was semi mild, so didn’t have freezing problems, but that might have because I was out there several times a week too.
