This is a shop made tool of sorts, an accessory for a tool would be more accurate. This shear is used to cut sign substrates, anything from coroplast to .080 aluminum. Due to limited space I need to move the shear around. This thing is forklift material when it comes to moving, so I built this dolly. The wheels are urethane So they roll well enough to make it a one man job to roll it around. Step & lock pedal on the back with a pair of shocks so it doesn't slam to the ground when the release is pulled. It's been doing the job for several years now. It also serves as a tray to catch sheets as they're cut and I added stops to cut substrates that are longer than the factory stop.
