I have been trying to make sure the tailstock is aligned on my 1946 Southbend 9A. Really puzzled here and maybe someone can point out what I might be doing wrong.
I mounted a magnetic base with dial indicator to a faceplate and then rotated it around the inside of the tailstock spindle, the outside, an inserted dead center, and an arbor/drill chuck assembly. One hopes the indicator will not move during this exercise. I was not that lucky, but you would think that any difference in readings (side to side, up and down) would be the same no matter what I measured off of Not the case. I can adjust side to side to be perfect using the spindle and then measure against the dead center, and the total side to side differential may be .010". I can not conclusively know whether the side to side adjustment is right, since it depends on what you measure. Same thing for vertical, but incredibly, the tailstock spindle (or dead center or drill chuck w/bit) all measure HIGH. Typically about .009"! Maybe someone shimmed the tailstock (far too much), or given the other results on side to side, maybe I just can't measure properly, or something is wrong with my indicator setup.
I installed a dead center in the head stock and another in the tailstock. I put them nose to nose. They are as dead on as I can see. I pinched a metal rule between the two to see if the ruler deflected from the points being off center. No deflection at all. How can this be if my measurements show at least a .009" vertical misalignment? I can not see why the measurements would be wrong. The tailstock and its spindle are both locked down during measurement. I rotated the indicator without it touching anything to make sure gravity is not affecting it. It appears solid.
I am exasperated. Suggestions welcomed!
Thanks.
- Phil
Thanks.
- Phil
