- Feb 28, 2019
- 499
TLDR: looking for a less subjective test for checking 304ss 16g sheet before and after annealing. I don't have any actual equipment (RC hardness tester for example) and I'm stuck with scratching it with a carbide scribe or attempting to file. There have to be other tricks, what are they?
Application: I'm micro machining (largest end mill .125, smallest .010 inch) 18g 304ss and finding that it's challenging with the equipment I have (small desktop CNC, no cooling). I have been successful - really not a lot of issues other than my carbide bits don't last very long.
I've read that annealing SS can / will make it more machinable.
Annealing process I'm using is to heat to 1900F in a heat treat oven for a while (soak) and then quench in water
Comparing pieces annealed/not annealed with a file test - feels like - the annealed is a littler softer than not annealed. Scratch test with a scribe is much more vague - hard to gauge how hard I'm scratching.
I've considered using a spring-auto punch tool, the assumption being that the strike will be more repeatable than anything I do by hand.
Other methods or comments greatly apprecieated.
