- Feb 7, 2014
- 350
Yesterday I was cutting a slot with the little CNC mill in semi auto mode when it started making clunking noises. Then it started skipping steps, and finally it froze up. The little steeper motor chunking away with no movement. Pulled the motor and the X screw was hard to turn with a wrench. After checking bearings and lube and all else I could think of, the only thing left was the gibs were too tight. Sure enough, it loosened up when the screws were backed off a bit. Now I've had them get loose before but never had them tighten themselves. Plenty of lube and no heat build up, but somehow the metal expanded, or something snuck into the shop and twisted the screws. We used to explain away such improbable occurances as bubbles of quantum uncertainty bursting nearby... but being near the ghostly time of year....
Larry
Larry
