Geometric die heads work great, but they are expensive, and generally have a small range. A New head alone usually runs between $1,200.00 and $2,500.00 each depending on size. To thread up to 1" you generally will need 2 different die heads. Then you need all the thread chasing dies for the size threads you want to cut. A new die set for each size usually runs between $200.00 and $400.00.
This setup is faster, and in most cases more precise than a standard hand die and therefore preferred in a production situation. However, unless you can find the size head and accompanying dies from a used machine dealer the system is all but cost prohibitive for a hobbyist.
As a side note one of the used equipment dealers, I visit has dozens of heads and thousands of die sets in stock. I doubt he sells more than a couple a year because of the cost, and the fact that dies don't interchange to different brand heads.
