- Jul 28, 2017
- 2,403
I have a 1.25" R8 indexable end mill. It accepts two TPx-322 inserts, where "x" is either G or C. According to one source, the C variant has ground-in "wiping flats" and is considerably more expensive, compared to the TPG with just one radius ground at each corner.
What is the purpose of the wiping flats? Is the TPC more suitable for end mills, compared to a TPG?
I suspect the answer will greatly depend on what I'm cutting and quality of finish I want but it would be good to know what the tradeoffs are for a 4X difference in price (from one online source I use, anyway).
I'm currently working on some hot-rolled to get it to size and the indexable end mill is mostly being used to get below the mill scale so in this case the finish really isn't a factor. Thinking that a cheaper set of TPG inserts would be just fine for that....unless the flats extend the life of the cutting edge by a factor of 4 or better....
