- Nov 16, 2015
- 3
Hello all,
I have been trying to machine a cylindrical part on my cnc mill and then thread mill it, but have been unable to hold correct diameters, which causes my threads to be either too loose or too tight. Hopefully you can help.
As for the details:
I'm using a 1 HP syil, 3 axis mill in conjunction with hsm express and solidworks. I use Gwizard for my speeds and feeds.
material is 4140 but I have had this problem with aluminum too. The part calls for milling the cylindrical shape then using the single form thread mill to cut the threads. On the other end of the part I perform a boring operation and then use the single form again. While modeling I look up the recommended min and max thread dimensions in machinery handbook.
Material: 4140
Spindle speed: 5000 rpm
Feedrate: 12 in/min for the external cuts and 5 in/min for internal boring
Cutter: .375" 4 tooth flat carbide endmill with 1.5" stickout
Cut Depth: .0375" for the external cuts
Finishing Pass: .005"
My cuts always come out under or over sized by multiple thou, any ideas why?
As for the details:
Material: 4140
