- Aug 1, 2022
- 137
Well, trying to save a buck and I picked up a used 1hp 3ph 208-230v 1725rpm c face motor for my metal bandsaw conversion.
The 1.27hp 10:1 gearbox fit perfectly. The VFD runs everything just fine at 15-30 Hz, then I cranked it up to 60 Hz and the motor started smoking.
Did I pick up a bad motor or did the gearbox add too much load?
The gearbox works just fine with a single phase motor at 1725rpm.
When it cooled down, I pulled the motor apart and found a bad bearing and the windings are toast.
I guess I’m going to try out one of those Amazon motors.
Pics:
Pics:
