Hello,
I have a project coming up that will require me to square up and drill a bunch of the same part. Anywhere between 6 and 12 dozen at a time. I typically do one offs or small runs of things messing about. This is crossing over into more of a production mindset for me and I want to approach it as such.
The part is basically a 2"x4" piece of .187" thick 6061 aluminum with a centerline hole on both ends. The 2" dimension and the thickness are not toleranced tightly, so I figured I would use 2" flat bar to start. I can either bandsaw or chop saw the stock to say 4 1/8" pretty comfortably.
From here I want to clean up the ends and then bring the length into spec....I have a mill drill and a Kurt 6" vise clone. I have a basic fixturing clamp kit as well as parallels, 123 blocks, and a vise stop. How would you go about setting up the parts?
If I laid them in the vise on the long axis I could even them up and hit them with a big endmill...then flip them back over tight against a stop since that side would be square now and then endmill them into spec. Would you stack them on the .187 dim with a piece of paper or stack them across on the 2" dimension? I was thinking of going the .187 dim since that would leave the vise in contact with each part.
Or I was thinking I could even them up, clamp them and then stand them up on the long axis with piece of paper in the vise to take out the slop. Then I could hit them with a fly cutter or a face mill...once they are evened up flip and then bring them down to spec.
Any pros/cons you can think of with either or another route entirely? How many would you try to do at a time?
JH
JH
