- Oct 20, 2014
- 495
Hi All,
Doing a bit of welding today, and have a question.
I've got a little Lincoln flux core wire welder. Works a treat. But the wire I have is for plain steel, not stainless.
I want to weld up a degassing wand for my aluminum melts. It's pretty simple, just a handle with a small stainless steel bowl on the end of it. Maybe a 3' long handle. Can I use this to weld stainless to mild steel, and get a solid bond? The usage is that you drop a packet of degassing agent (either commercial degas tablet, or granular pool shock) wrapped in aluminum foil into the melt, then push it to the bottom with the wand. The degasser decomposes, and reacts with the entrapped hydrogen in the melt to remove it. Creates hydrochloric acid, which bubbles out of solution, in a rather volatile fashion. Definitely stand up-wind, a distance off from it.
I figured that as long as I was welding lugs to the crucible (steel pipe crucible), and welding up a new pouring shank, I might as well make the wand while I had everything out. It doesn't have to be structural, but I don't want it to fall off, either. Trying to fish that out of a pot of 1400 degree molten aluminum wouldn't be easy, and I wouldn't want to screw up a pour by it tumbling out and obstructing the sprue while pouring. Molds have to be poured in one go, as fast as it'll take the metal. Stopping and starting is sure to generate a short pour at the very least, and a poorly-bonded nearly-two-piece casting at best.
Ideas? I'd hate to have to buy a roll of stainless wire (and a piece of stainless for the handle) just to weld a couple of tacks.
