A friend of mine purchased a 5x7 Kalamazoo well saw from the auction for a steal. Bad part is it was missing the moveable jaw and only the acme nut for the jaw screw is there. I’ve already made the vise jaw and now I need to make the nut. What bronze would be the most durable. The nut is different in the way that once pressure is released on the vise it can be rapidly moved. I have the same saw so duplicating the nuts specs should be easy but I’m alittle confused on which material to use. The nut only has threads on half the hole and the hole is elongated with a spring to be able to disengage from the screw for rapid movement. Any advice on what bronze to use. I’ll try and post a picture of the nut arrangement later.
